Einleitung
We disassembled this computer on October 15, 2008.
Was du brauchst
Apple boasts that, "The new MacBook packaging is 41 percent smaller than the previous generation" and is made from recycled material.
Smaller packaging, they say, means fewer planes to transport the same number of products.
Follow our updates on twitter.
It looks like a MacBook Air from the top, but it's about 25% thicker than the thickest part of the Air, and almost 6 times thicker than the thinnest part.
To be fair, though, it's about 12 percent thinner than its predecessor (0.95 in vs. 1.08 in) and 10 percent lighter (4.5 pounds vs. 5 pounds).
In the box:
85-page user's manual
Restore DVDs
60-watt AC adapter
AC adapter extension cable
Cleaning cloth
There's a new Mini DisplayPort (fourth from the right), and a complete lack of a FireWire port.
It may be hard to tell from the image, but there are now 8 lights on the battery indicator, and it's conveniently located where you can actually see it.
Opening the battery latch.
For those hurt by the financial crisis, a coin is no longer required.
The hard drive is on the left, and the battery is on the right.
The new MacBook uses the same hard drives as previous MacBook models.
Shameless plug: If you're not ready for a new machine, you can upgrade the hard drive in any Apple laptop. We have free guides for most models that make hard drive replacements easy.
Beautiful computer . Even in 2017
The battery is 45 watt-hours compared to 55 on the previous generation. It's also almost 20 percent lighter (302 g vs. 402 g).
Still, Apple claims that you'll get 5 hours of wireless productivity (with the display brightness set to 50 percent).
Disconnecting the hard drive.
To replace the hard drive, you'll need a T6 Torx screwdriver to transfer the hard drive mounting screws to the new drive.
The bottom panel is attached by 8 screws:
One 3 mm Phillips in the top left corner.
Four 3.5 mm Phillips along the bottom.
Three 13.8 mm Phillips along the top.
Removing the bottom panel provides access to the RAM, optical drive, display hinge, fan, and logic board.
It looks like the only really hard part to replace will be the upper case and keyboard.
Removing the RAM
Shameless plug: You can upgrade your existing MacBook or MacBook Pro to 4 GB. We'll also be offering the RAM for the new Unibody machines in the near future.
It's been tested... 6GB max. Why? Who knows, but the computer will not recognize 8GB (and a 4GB chip for this machine is still stupid expensive...)
Disconnecting the subwoofer and optical drive cables.
The optical drive is held in by the following 4 screws:
Three 2.5 mm Phillips.
One 3.7 mm Phillips.
The optical drive, now SATA.
The optical drive shows a manufacture date of October 2008. That drive sure got from the factory to us fast!
Removing the logic board.
This may be the most beautiful laptop we've disassembled. Apple has a right to be proud of their engineers and manufacturing team.
Zitat von pjohn07:
I'd love some more detail on which screws need to be removed in order to remove the logic board.
This is a teardown, and should not be used as a repair guide due to many missing steps. The repair guides for this machine can be found here.
The top of the logic board. (Click on the image for a larger version.)
Part numbers found thus far:
Penryn Intel Core 2 Duo Mobile Processor P8600 5827B394 SLB4N AV80577P8600 2.40/3M/1066
Cypress USB Controller CY7C638 33LFXC 0825 KOR 633013
K0328 8F1 50C8 & K0305 8F5 5022
F2117LP 20H V AF03370 0824JPN
REALTEK RTL8251CA 86085S2 G831 TAIWAN
Compare this to the previous MacBook logic board.
The bottom of the logic board.
Cypress PSoC Mixed-Signal Array CY8C24794-24L FXI 0831 A 04 KOR CYP 637569
Realtek HD Audio Codec ALC885 87J24A1 G83283
TDK 6T213HF 0838 d
ISL95O4 BHRZ H0832BB49
APP001 928 3T 0829A
SN 802043 TI 87K JR7C G4
SN802043 is the actual part number (The numbers 87K JR7C G4 are different on each IC batch produced). This part is hard to get (unless you live in USA) and is not listed in Texas Instruments website http://www.ti.com If anybody in UK has this part, please Add a comment.
Removing the right speaker and subwoofer.
The new MacBook received a welcome speaker upgrade. In the second image, the old plastic MacBook's speakers are on the left, and the new MacBook's speakers are on the right.
The elegant new glass and Aluminum display assembly.
Amazingly, the new display assembly weighs slightly less than the previous MacBook's plastic display assembly.
could this be replaced with a newer macbook air 13.3inch screen thereby increasing this macbooks resolution?
All major components - only 4.5 pounds, not bad for a full-featured, metal laptop.
7 Kommentare
While disassembling my MacBook 2008-11 model as seen in these pictures, I was careful to lay out and label each part to reassemble after attempting to repair from water damage. When I lifted the hard drive a small black rectangular bracket about 1/2 wide with a small square on the back and an extruding piece against the black hollow square tha appears would go over a screw hole; dropped to the floor. It has part number ZYI-4 as best I can make out. Does anyone know where this goes? I cannot figure it out. Thanks!!!!
Hi Label beetween keyboard a lil bit part i dont see in my macbook. This part is ? Because my macbook dont turn on.
Are the logic boards for 2.0GHz and 2.4GHz interchangeable?
