Was du brauchst
Remove battery, and the sticker underneath.
Remove the two T5 torx screws.
Using a pry tool, start near the strap and pry away grip portion until it starts to hinge from the top.
Carefully pull back and down to remove the grip, clearing the grip trigger's hinge.
Using a straight-edge, wedge the inner ring away from the outer starting at the seam to separate the sensor array. Pull the sensors down carefully.
While pulling down on the sensors, push the outer ring towards the buttons. A uncomfortable amount of force is required to separate.
Remove two T5 torx screws near the trigger to separate the cover for the buttons.
Unscrew four T5 torx screws around the controller to separate the bottom PCB. One is facing outwards near the trigger. Three others are opposite from the battery compartment.
Lift the wires up, and then remove the handle. Make sure to disconnect the wire or you may sever it.
2 Kommentare
is there a place to get individual parts for the controller?
