Einleitung
Here at the Moebius Foundation, we are always looking to advance humanity’s technological level, no matter the cost. When advanced alien races refuse to share their technology with us, we simply see it as an occupational challenge.
We have been trying to tap into the Protoss psionic energy matrix without success for years. The floating pylons they use to distribute the energy are immovable, and field scans yield nothing.
That all changes today. With great effort, field agents were able to procure a movable pylon! This must be a prototype version of the field-deployed ones. With its secrets, we may be able to construct our own wireless power system!
Let us proceed with the teardown before some unlikely hero inevitably kicks down our door and obliterates the lab.
This is an iFixit after-hours project. Any views expressed in this guide are those of the authors and do not necessarily reflect the official policy of iFixit.
Was du brauchst
Here's what we theoretically know about these pylons:
Uses Khaydarin crystals to channel energy
Takes 100 minerals and 30 seconds to warp in
Floats in the air and glows
Provides supplies for 8 units
Scientific analysis of our "prototype" specimen yields the following data:
2 unregulated USB ports capable of sourcing 2A total (or whatever max current it's supplied with)
The crystal can be activated to glow blue with a switch
Prototype: must be powered by a wired 5V 2.1A DC power supply
In diesem Schritt verwendetes Werkzeug:Manta Driver Kit - 112 Bit Driver Kit$69.95
Luckily, we just got a shipment of high quality tools! And, they're so nice looking!
It's slightly unsettling that even the Protoss are using Phillips screws. It must be a universal standard.
The only thing worse than esoteric screw types? Low quality ones. These screws are made of soft metal and are easily stripped. This must be a side-effect of their warp-in technology.
Phew! It looks like the sensitive monitoring equipment survived the explosion. After we scrape up the charred remains of the interns, we shall proceed as planned.
And here we see the casualties of the warp-in technology:
Energy transfer conduits that are dangerously pinched
Low reliability conduit-to-socket connections
We finally get a glimpse of the Protoss' power channeling circuitry.
It is surprisingly sparse and low tech, consisting mostly of surface mount resistors and common electronic components...
We've been bamboozled by the Protoss! This isn't a real pylon; it's just a toy! A decoy!
Contact our field agents and fire them! Literally, with a Firebat executioner squad.
Speaking of being fired, someone’s going to have to take the fall for this. Wait right here! I’m going to go check on…something in the hanger bay…
6 Kommentare
Fairly disappointed with this thing and the quality of the electronics but alas, it’s a toy made in china. Took me about 4 years to get around to it but I finally fixed the faulty power connector thanks to you guys. Thank you so much for this. I could not figure out where those clips were behind the larger sides.
Same here, thank you so much for this guide, the connector on my pylon became loose to the point where I have to apply downward force onto the power connector in order for it to light up. After about 5 years now I am finally able to open it up to try to repair it, thanks for the guide!
