Was du brauchst
Use a 3.8 mm gamebit screwdriver to undo the 3 screws on the rear of the cartridge, and set them aside.
Gently lift out the PCB, and clean the pins with isopropyl alcohol and a cotton swab. if the pins still remain dirty, carefully sand the pins with a very fine-grit sandpaper.
