Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Rubik's Cube zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Rubik's Cube Teardown, Rubik's Cube Teardown: Schritt 1, Bild 1 von 3 Rubik's Cube Teardown, Rubik's Cube Teardown: Schritt 1, Bild 2 von 3 Rubik's Cube Teardown, Rubik's Cube Teardown: Schritt 1, Bild 3 von 3
    • Turn the top row so that each corner is roughly halfway between the sides
    • Push the pieces up until they pop out of the cube, then, slide the rest out
    • Repeat this process until you clear the level
  2. Rubik's Cube Teardown: Schritt 2, Bild 1 von 2 Rubik's Cube Teardown: Schritt 2, Bild 2 von 2
    • You should be able to just directly pull out the rest of the blocks, like so
    • And there you have it!
    • You'll have the center piece, with the six centers of the six sides, the turning mechanism
  3. Rubik's Cube Teardown: Schritt 3, Bild 1 von 2 Rubik's Cube Teardown: Schritt 3, Bild 2 von 2
    • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
    • It helps to start with the middle pieces first
    • Don't be afraid to use force!
    • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
    • Again- don't be afraid to use force!
    Rubik’s Cube BROKEN using this method on a cube with a Circular Center. Last corner piece snapped when pushing in. Not recommended to use ‘force’ as the little plastic pieces can’t withstand it.
    * This method only works if you have a Rubik’s Cube that looks exactly like the one in the video when disassembled! If your Rubik’s Cube looks different (circular center) DO NOT USE THIS METHOD!!!!!
    Booya Tribe - Antwort
rab777hp
20.333 Reputation
3 Anleitungen geschrieben
OPEN Mitglied von OPEN
Community
82 Mitglieder
25 Anleitungen geschrieben
6 Kommentare
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - Antwort
lol don’t blame you, can’t stand the thing
Luke -
that method just broke my rubiks my cube.. thanks anyway
hamzamagdy888 - Antwort
my middle peices came out cant fix it
jax - Antwort
can someone tell me how to fix it
jax - Antwort
grr i am mad that i cannot fix my rubik’s cube!
Devin Plante - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 45
Insgesamt: 24,572
