Zum Hauptinhalt wechseln
Was du brauchst
Einführungsvideo
Dieser Teardown ist keine Reparaturanleitung. Um dein iPad Mini 6 zu reparieren, verwende unsere Fehlerbehebungsseite.
    Fazit
    • A single Phillips screwdriver takes care of all the screws.
    • Some components are modular, but all repairs will require painstakingly ungluing the glass display.
    • The iPad mini's battery is fastened with repair friendly stretch-release adhesive, but the removal process is marred by additional adhesive on other parts of the battery.
    • Gobs of adhesive hold many parts and cables in place, complicating all repairs.
    Reparierbarkeits-Index
    3
    Reparierbarkeit 3 von 10
    (10 ist am einfachsten zu reparieren)
10 Kommentare zur Anleitung
does the ipad cellular version use qualcomm’s x55 or same as iphone 13’s x60 modem?
abdulaziz khalil - Antwort Teilen
Why would I fixit team be so cheap and bought only WiFi model for teardown and not post this info which cellular modem is used ?
peterkor - Antwort Teilen
We need to know the battery mAh == Where is the full written review?
Lindy Xi - Antwort Teilen
The battery specs can be found on the iPad mini 6 device page! It has a 5034 mAh cell.
Carsten Frauenheim - Antwort Teilen
Umm.. where is the full written teardown with hi-res pictures…?
inwoochoi - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 18
Letzte 7 Tage: 116
Letzte 30 Tage: 484
Insgesamt: 46,384
