Einleitung
Let’s peek inside Apple’s 6th-generation iPad mini! Is this redesigned mini iPad holding any mini secrets, or is it just a smaller iPad Air? Time to tear it down.
For more exciting teardowns and repair news, be sure to follow us on Instagram, Twitter, and Facebook. For iFixit delivered, subscribe to our newsletter.
Was du brauchst
Einführungsvideo
- A single Phillips screwdriver takes care of all the screws.
- Some components are modular, but all repairs will require painstakingly ungluing the glass display.
- The iPad mini's battery is fastened with repair friendly stretch-release adhesive, but the removal process is marred by additional adhesive on other parts of the battery.
- Gobs of adhesive hold many parts and cables in place, complicating all repairs.
Fazit
Reparierbarkeits-Index
3
Reparierbarkeit 3 von 10
(10 ist am einfachsten zu reparieren)
7 Kommentare zur Anleitung
does the ipad cellular version use qualcomm’s x55 or same as iphone 13’s x60 modem?
abdulaziz khalil - Antwort
Why would I fixit team be so cheap and bought only WiFi model for teardown and not post this info which cellular modem is used ?
peterkor - Antwort
We need to know the battery mAh == Where is the full written review?
Lindy Xi - Antwort
The battery specs can be found on the iPad mini 6 device page! It has a 5034 mAh cell.
Carsten Frauenheim -
Umm.. where is the full written teardown with hi-res pictures…?
inwoochoi - Antwort
Which GPS chip is iPad mini 6 2021 using? What signals and frequencies are supportet? GPS, GLONASS, NAVIC, BeiDou, Galileo, SBAS, and QZSS ? L1/L2/ B1/ E1 & L5/E5a/B2a ? Sony? Broadcom?
Pooh the Great - Antwort
Hi,
I’ve got a special question because I want to know if the USB-C Charging port can be changed to a lightning charging port? Thank for your help!
Kind regards,
Michael
michael ernest - Antwort
