Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Computer is Overheating
When the computer is running multiple programs, it overheats.
Vent is Covered
Make sure the vent is not covered. Using the device on your lap or on a blanket/pillow could cover the vent
Dust Accumulation
The buildup of dust can cause a device to overheat. To remove the dust, use a compressed air can to blow out dust from the vents.
Faulty Part
If the above steps still result in an overheating device, you may have to replace the fan.
Damaged Hinges
The hinges on your laptop are breaking or broken.
Forceful Use
Picking the device up by its lid, dropping the device, or opening it beyond the angle it is meant to be open can damage the hinges.
Faulty Hinges
The hinges of your laptop may be made with a metal that is not very durable, and may break overtime. Replace broken hinges using this guide.
Computer Freezes or Randomly Shuts Down
When you are using the device, it freezes or shuts down when you do not power it down.
Device Overheats
If the device freezes, and it is overheating, refer back to the troubleshooting page” Computer is Overheating” section.
RAM is faulty
If the device does not have enough RAM, it may freeze or shut down. This issue can be avoided by installing more RAM onto the computer.
Hard Drive is faulty
When the hard drive fills up, the speed of the device will decrease. If there is clicking or other disk noises, back up the hard drive and replace it using the hard drive repair guide.
Unresponsive Touchpad
You attempt to move the mouse with the touch pad, but it will not move on the screen.
Laptop Freezes Up
Try restarting the computer and see if the computer reboots with a responsive touch pad.
Touchpad is locked
Tap the touchpad 2 times on the upper left had corner, an orange light should turn off in the corner of the touchpad when it is unlocked.
Outdated Driver Software
The driver software can become outdated and will render the touchpad unusable
Touchpad needs replacement
Reference the guides to learn how to remove and replace the touchpad.
Screen Distortion
The screen will be black, blue or have lines across it.
Damaged wires in the hinges
There is a flat ribbon cable of wires inside the left hinge that can be cracked or damaged over time with repeated opening and closing of the laptop. This cable will need to be replaced.
Dead or Stuck Pixels
If there is a green, blue dot on the screen the pixels may be stuck, there is online software that can help unstick those pixels. If the pixel is black it might be dead and need a screen replacement.
The Blue Screen of Death
The screen turns blue with white writing this is caused by unsuspected software errors in the devise drivers. Run the Reimage professional Windows system repair software which will run a scan and can automatically fix the issues.
0 Kommentare
