Von Studierenden verfasstes Wiki
Ein tolles Team von Studierenden aus unserem Bildungsprogramm hat dieses Wiki erstellt.
Before trying to diagnose the issue alone, there is a built in diagnosis setting on the camera.
- press the "?" button on the bottom right of the camera near the menu button.
- Navigate and select "Self-diagnosis indicators."
- There will be error codes that pertain to the device and the cause of the fault in the camera.
Camera Fails to Power On
Possible diagnosis for why the camera will not power on and instructions for repair.
Drained/Bad Battery
If the camera will not turn on, it may simply have a dead battery or battery pack may not be inserted correctly. Sometimes, after inserting the battery pack into the camera, it may take a few moments for the camera to power up. Make sure that the battery pack is inserted correctly. The battery pack will discharge by itself even if it is used. Charge the battery pack before use. Check that the battery pack type is compatible.
The power may turn off automatically, to protect the camera depending on the camera and battery temperature. In this case, a message is displayed on the screen before the power turns off. If the camera is not used for a certain period of time while the power is on and [Power Save] is set to [Standard] or [Max], the camera turns off automatically to prevent wearing down the battery pack. Turn on the camera again.
If the battery does not hold a charge as long as it use to then the battery pack needs to be replaced.
There is a guide, located here, that goes over how to replace the battery.
Bad Display
If there is no obvious damage to the LCD screen, then it is possible the display is bad and needs to be replaced. A quick way to diagnose if the display screen needs to be replaced is:
- Make sure the camera is powered on, the ON/OFF button should be illuminated with a green light.
- Press the Finder/LCD button located next to the ON/OFF button. This will toggle between the LCD screen and the view finder.
- If the screen is still black then it is likely that your LCD screen needs to be replaced.
There is a repair guide, located here, that disassembles the LCD screen and circuit board.
There is a replacement guide, located here, that demonstrates how to replace the View Finder.
Charging Issues
Possible diagnosis for why the camera may have charging issues and instructions for repair.
Charger Failure
Is the battery charger plugged into the wall? Do you know if that outlet has power going to it?
Is the charging cable plugged into the camera correctly? The ON/OFF button should be flashing orange while charging. Once the battery is fully charged the ON/OFF button should stop flashing.
Try plugging the camera directly into a computer's USB port while the battery is inserted in the camera. If the ON/OF button is flashing an orange light then the camera is charging. If the ON/OFF button is not flashing then the battery needs to be replaced.
If the ON/OFF button is flashing while plugged into a computer's USB port then the charger is broken and needs to be replaced.
Problems such as the camera appearing to not understand that the charger has been inserted is a problem for some users. It has been reported that even using several different chargers, the camera still does not connect to the charger therefore allowing the battery to recharge. This problem could be due to damage by the users that have reported the problem or manufacturing assembly problems when making the product.
There is a replacement guide, located here, that walks through how to replace the HDMI/USB port.
There is also a replacement guide for how to replace the motherboard, located here.
Charge Indicator is Incorrect
If the charge indicator is incorrect, this is caused when the camera is used in an extremely hot or cold location.
Battery capacity decreases over time and through repeated use. If decreased usage time between charges becomes significant, it is probably time to replace it with a new one.
The Power/Charge Lamp of the Camera Flashes while Charging the Battery.
The Power/Charge lamp of the camera flashes infrequently when you use a battery pack that has not been used for a long time. In such cases, remove the battery pack from the camera and re-insert it.
The Battery is Not Charged Even if the Power/Charge Lamp Turns Off and Charging is Finished.
This happens when the battery pack is charged in an extremely hot or cold location. Charge the battery pack within the proper charging temperature range of between 10°C to 30°C (50°F to 86°F).
Lens Fails to Zoom
Possible diagnosis for why the camera lens fails to zoom and instructions for repair.
External Button May be Broken
When you actuate the zoom lever while the camera is powered on and the lens fails to zoom. This might indicate that the zoom lever might be broken and need replacing.
Internal Motor May be Broken
If there is an audible grinding while the lens is zooming in, this may be a sign that the motor that controls the lens movement is on it's way out and should be replaced.
Settings or Mode May Need Adjustment
The optical zoom in Sweep Panorama mode cannot be used.
The camera will not enable zoom functions other than optical zoom when:
- [Background Defocus], [Backlight Correction HDR] or [Advanced Sports Shooting] mode is selected in the Scene Selection
- The Smile Shutter is working.
- [Self-Timer] is set to [Self-portrait One Person] or [Self-portrait Two People].
Flash Does Not Function Properly
Possible diagnosis for why the camera flash does not function properly and instructions for repair.
Flash Hardware May be Broken
If there is no obvious damage to the pop-up flash that would prevent it's proper function, but the flash does open when the button with the flash icon on it is depressed, then the light might need to be replaced.
Pop-up Flash Failing to Open
When the flash button is depressed and the flash does not pop open, given that there is no obvious obstruction that would prevent it's proper function, then either the flash button is broken or the hing for the flash may be broken.
Fuzzy White Circular Spots in Images Shot with Flash
Particles (dust, pollen, etc.) in the air reflected the flash light and appeared in the image. This is not a malfunction.
The flash cannot be used when:
- Burst mode is selected. [Details]
- [Anti Motion Blur], [Night Scene], [Hand-held Twilight], [High Sensitivity], [Fireworks] or [Advanced]
- Sports Shooting] mode is selected in Scene Selection
- Shooting in Sweep Panorama mode
- Shooting in movie mode
Set the flash to [On] when the Scene Selection mode is set to [Landscape], [Gourmet], [Pet], [Beach] or [Snow] mode.
External Buttons Will not Respond
Possible diagnosis for why the camera external buttons will not respond and instructions for repair.
Navigation Buttons are Unresponsive
Is there any visible obstructions that would prevent the buttons from operating correctly?
If there is no obvious damage to the navigation buttons themselves, they may need to be replaced.
Frozen/Unresponsive Screen
Possible diagnosis for why the camera flash does not function properly may have a frozen or unresponsive screen and instructions for repair.
Low Battery Indicator
Battery may need charging. Look at the top left corner of the screen to see if the battery icon indicates that the battery is low. If the battery is low, turn off the camera and charge the battery.
Display Screen is Unresponsive or Not Working
Try restarting the camera by holding the ON/OFF button until the camera powers off, once the camera is of press the ON/OFF button again to restart the camera. If the issue persists then the screen may need to be replaced.
8 Kommentare
why do I have to reset the time, language etc. every time I turn the camera on or off ?
moepappy - Antwort
I turn the power on and when I press the shutter bution to take a photo, the camer shuts off...no power
Ken - Antwort
Still waiting for an answer...
Ken - Antwort
Hi!
I´m really struggling with my Sony. I have used it for a couple of years (w/ 3 batteries) and now it suddenly “died”. I cannot turn it on anymore. The battery is placed as before and if I connect it to the PC with USB cable, the charge light goes on for a moment and then turns off as the battery is fully charged. As supposed to. I have checked the battery voltage and it is okay. So, the battery is not dead.
Is there any other things I could do to make this work? It does not response the ON/OFF button or any else…
Thanks for your help!
Regards, Pablo
Pablo Casso Photography - Antwort
My sony cyber shot dsc-hx300 is creating issues in the power button, some time it is not starting after pressing the button, and some time it not closing after pressing power button. Can't understand what should I do. If anyone has any suggestions then please tell me.
viraj chakraborty - Antwort
