My handycam is not turning on
Make sure the power button is turned on
Before checking the internal components of your Handycam make sure the
power button has been pressed once. The power button is located on the inside of the LCD screen.
Low battery
The battery might not be charged on the device. To charge the battery, connect the AC Adaptor and the power cord to the device to a wall outlet. When charging begins, the symbol that resembles a lightning bolt with an arrow at the end will light up. Once charging is complete, this same symbol will turn off.
If you complete this and your handycam still does not turn on, then you know the battery is not the issue.
My handycam battery is dying so quickly
Turn off the GPS
Having the GPS setting turned on can drain your battery. Try having the GPS setting turned off when you are not using it. If you try this and the battery is still dying quickly, you might have to replace the battery.
I think my hard drive crashed
Error E 31 00 appears
If this message appears on your screen then this means that you will have to take your handycam to an electronic store to get the camera fixed or replace the Sony Handycam HDR-XR500 hard drive yourself...
Ein Kommentar
Hi, how to find the model for the hard disk inside my Sony Camera HRD-FX500E?
i want to replace with a bigger one, or equivalent, since it shows signs of weakness.
thank you
Didier KEUSCH - Antwort
