Zum Hauptinhalt wechseln
Apples Mainstream-iPhone 2021 wurde am 24. September vorgestellt und kommt mit einem 6,1-Zoll-OLED-Display, einem dualen 12-MP-Kamerasystem und in fünf verfügbaren Farben. Nachfolger des iPhone 12.
99 Fragen Alle anzeigen
Charging port clogged with debris, possible bent pins
Picked this up for cheap second hand as it had issues with charging, after looking at it there seems to be some sort of thick debris in the charging port which I think may be the root of the issue, a lightning connector doesn’t go all the way in, it doesn’t “click” like it would with a clean phone, after looking closer I’m thinking there may also be bent pins and this May be a full Charing port replacement.
If it’s just debris should a tooth pick / Compressed air do the trick?
The phone powers on and work perfectly, and can charge through wireless charging, it’s just the lighting port that is the issue
I will attach images of the port as I’m not 100% sure if they are bent or not
any help is appreciated :)
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
I'd power the phone off and pick away at the debris with a small needle or a thin piece of plastic. Over time, dust seems to have been compacted at the bottom of the lightning port, preventing the charger from going deeper into it and clicking/latching on properly. You could also carefully drip some high-purity isopropanol into the port to help unstick the compressed residues.
There seems to be a good chance of it working well after that, and a charging port replacement seems to be unnecessary.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
AnAceCase wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 81
