Battery
Keine Antworten 0 Punkte |
My laptop restarts suddenly when I plug in the charger |
1 Antwort 0 Punkte |
Should I get a new Laptop? |
Werkzeuge
Es werden ein paar gängige Werkzeuge verwendet, um an diesem Gerät zu arbeiten. Du wirst nicht jedes Werkzeug für jeden Schritt benötigen.
Troubleshooting
If you are having difficulties with the Toshiba Satellite L755-S5244, try referring to the troubleshooting page for this device.
Background
The Toshiba Satellite L755 is a 15.6 inch laptop released in 2011. There have been no recalls related to the Satellite L755-S5244. The general dimensions of the laptop are 15” x 10” x 1.25”.
The Satellite L755-S5244 has an Intel i5 2nd generation CPU, with 4 GB of RAM. The battery has up to 6 hours of life and is removable, and the laptop uses a standard laptop charging port. There are 3 USB 2.0 ports, one each of VGA, LAN, and HDMI ports, and separate headphone-out and microphone-in audio jacks.
Identification
The laptop can be identified by a panel on the bottom of the laptop that contains the part number, serial number, and other identification information. The top line of the panel will say Satellite L755-S5244, and the part number PSK1WU-05L004 should also appear on the line below it.
Additional Information
Toshiba Satellite L755-S5244 Specifications
