Zum Hauptinhalt wechseln
MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy)
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy), Lower Case: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 2, Bild 1 von 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 3, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 3, Bild 2 von 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy), Battery Connector: Schritt 4, Bild 1 von 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 5, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 5, Bild 2 von 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 6, Bild 1 von 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy), Right Speaker: Schritt 7, Bild 1 von 1
    • Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
  8. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 8, Bild 1 von 1
    • Grasp the I/O board cable bracket with a pair of tweezers and remove it from the MacBook.
  9. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 9, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 9, Bild 2 von 2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  10. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 10, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 10, Bild 2 von 2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  11. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 11, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 11, Bild 2 von 2
    • Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board.
  12. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 12, Bild 1 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 12, Bild 2 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 12, Bild 3 von 3
    • Carefully peel the right speaker cable off the upper case.
  13. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 13, Bild 1 von 1
    • Remove the following screws securing the right speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  14. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 14, Bild 1 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 14, Bild 2 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 14, Bild 3 von 3
    • Lift the right speaker from the cable end and pull it free from the case.
  15. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy), Left Speaker: Schritt 15, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy), Left Speaker: Schritt 15, Bild 2 von 2
    • Insert the tip of a spudger under the left speaker cable near the connector and lift it up out of its socket on the logic board.
  16. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 16, Bild 1 von 1
    • Remove the following screws securing the left speaker to the upper case:
  17. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 17, Bild 1 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 17, Bild 2 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 17, Bild 3 von 3
    • Lift the corner of the left speaker up and slide it out around the battery to remove it from the upper case.
    • Be careful not to snag the speaker cable on the screw hole post in the side of the case.
  18. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy), Battery: Schritt 18, Bild 1 von 1
    • Remove the five 3.7 mm T5 Torx screws securing the battery to the upper case.
  19. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 19, Bild 1 von 1
    • The liquid adhesive remover provided in your iFixit battery replacement kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
  20. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 20, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 20, Bild 2 von 2
    • If you have an iFixit battery kit with liquid adhesive remover, it's time to get it prepped.
    • Alternatively, if you are using the hot iOpener method, skip the following three steps.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
  21. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 21, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 21, Bild 2 von 2
    • Open your container of adhesive remover.
    • Fill the syringe included in your kit with a small amount (approximately 1-2 milliliters) of adhesive remover.
    • It's best to fill the syringe with no more than about 1-2 milliliters of adhesive remover at a time, so as to avoid accidentally applying too much.
    • Refill your syringe as needed throughout the rest of this procedure.
  22. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 22, Bild 1 von 1
    • Apply a small amount of adhesive remover (approximately 1 ml) evenly under the edge of the rightmost battery cell.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
    • Do not apply more than 1 ml of the adhesive remover at a time. Using too much can allow the adhesive remover to make its way to the backside of your keyboard and potentially damage it.
  23. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 23, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 23, Bild 2 von 2
    • If you don't have a liquid adhesive remover, you'll be using a hot iOpener to warm and soften a section of the adhesive securing the battery to the upper case, and then carefully prying at that point.
    • Use the hot iOpener to cover half of the two right-most battery cells.
    • After about a minute, reheat the iOpener and move it to cover the other half of the right-most battery cells.
  24. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 24, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 24, Bild 2 von 2
    Plastic Cards
    $2.99
    Kaufen
    • Push a plastic card between the right-most battery cell and the upper case, cutting the adhesive between the two.
    • Throughout this procedure, be careful not to damage any of the battery cells with your tools. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
    • When using the hot iOpener method, if you encounter significant resistance to prying, stop and use the iOpener to reheat the section you're working on.
  25. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 25, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 25, Bild 2 von 2
    • Use the plastic card to pry the right-most battery cell up from the rear case.
  26. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 26, Bild 1 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 26, Bild 2 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 26, Bild 3 von 3
    • Repeat this procedure with the adjacent battery cell:
    • Apply a small amount (about 1 ml) of liquid adhesive remover under the battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
    • Alternatively, re-heat this section with your iOpener if needed.
    • Push a plastic card about an inch between the battery cell and the upper case, and slowly pry the cell up to separate all of the adhesive.
  27. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 27, Bild 1 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 27, Bild 2 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 27, Bild 3 von 3
    • Temporarily leave your plastic card underneath the two rightmost battery cells to prevent them from re-adhering to the upper case.
    • If using an iOpener, reheat it and reapply it, this time to the left-most battery cells.
    • Again, leave the iOpener in each position for about a minute, reheating in between, to heat each half of the left-most battery cells.
  28. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 28, Bild 1 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 28, Bild 2 von 3 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 28, Bild 3 von 3
    • Repeat the above procedure to separate the two leftmost battery cells from the upper case.
    • Remember to apply a small amount (about 1 ml) of adhesive remover to each battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
    • Use a second plastic card to separate the two leftmost battery cells from the upper case.
  29. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 29, Bild 1 von 1
    • Leave the second card in the corner between the two left cells.
    • In the following steps, you can either use a third card, or the card from the right corner. The right corner adhesive should be dry/cool enough that the cells can easily be pulled up again when needed.
  30. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 30, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 30, Bild 2 von 2
    • To separate the adhesive securing the final two, middle battery cells, apply another 1 milliliter or so of liquid adhesive remover (or your iOpener) to each cell.
    • It may help to elevate one side of your MacBook Pro a few inches so that the adhesive remover flows in the correct direction, underneath the battery cells. You can use a sturdy book or foam block to prop up one side of your MacBook Pro while you work.
    • Insert the card about an inch between the left-center battery cell and the upper case, separating the adhesive between the cell and the case.
  31. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 31, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 31, Bild 2 von 2
    • Pull the card back out and insert it about an inch between the right-center battery cell and the upper case, separating the adhesive between the cell and case.
  32. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 32, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 32, Bild 2 von 2
    • By this point, the outer cells should be free, and you should only encounter resistance from the two center cells. If this is not the case, go back and completely loosen the four outer-most cells from the upper case.
    • Pry up on the two center cells to separate the last of the adhesive and lift the battery from the device.
  33. MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 33, Bild 1 von 2 MacBook Pro 13" Retina Display Mid 2014 Battery Replacement (Legacy): Schritt 33, Bild 2 von 2
    • Remove the battery.
    • Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
    • Calibrate your battery before using it: allow it to drain overnight, then charge it to 100% and drain it again until your MacBook Pro shuts down automatically. Charge it again and use it normally.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sam Goldheart
465.870 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.222 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 18
Insgesamt: 923
