Zum Hauptinhalt wechseln
iPod Touch 5th Generation Rear-Facing Camera Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: Schritt 1, Bild 1 von 3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: Schritt 1, Bild 2 von 3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: Schritt 1, Bild 3 von 3
    • Insert the flat end of a spudger between the rear-facing camera and its frame.
    • Gently twist the spudger to free the camera.
    • Lift the rear-facing camera up out of its socket, and remove it from the iPod Touch.
  2. iPod Touch 5th Generation Rear-Facing Camera Replacement: Schritt 2, Bild 1 von 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: Schritt 2, Bild 2 von 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: Schritt 2, Bild 3 von 3
    • Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable.
    • Run the spudger along the full length of the tape to disconnect it from the rear case.
  3. iPod Touch 5th Generation Rear-Facing Camera Replacement: Schritt 3, Bild 1 von 2 iPod Touch 5th Generation Rear-Facing Camera Replacement: Schritt 3, Bild 2 von 2
    • Peel and remove the foam tape from the rear case of the iPod.
  4. iPod Touch 5th Generation Rear-Facing Camera Replacement: Schritt 4, Bild 1 von 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: Schritt 4, Bild 2 von 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: Schritt 4, Bild 3 von 3
    • Use the tip of a spudger to peel up the edge of the tape covering the button ribbon cable.
    • Use tweezers or your fingers to peel the tape up from the rear case, and remove it from the iPod.
Abschluss
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.228 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 11
Insgesamt: 97
