Zum Hauptinhalt wechseln
MacBook Unibody Model A1342 Rear Speaker Replacement
Was du brauchst
  1. MacBook Unibody Model A1342 Rear Speaker Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Remove the eight 4 mm Phillips screws securing the lower case to the MacBook.
  2. MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 2, Bild 1 von 3 MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 2, Bild 2 von 3 MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 2, Bild 3 von 3
    • The lower case is constructed of rubber-coated aluminum. Do not excessively bend the aluminum during removal, as any permanent deformation will cause tolerance issues after reassembly.
    • Slightly lift the lower case near the vent opening.
    • Continue running your fingers between the lower and upper cases until the upper case pops off its retaining clips.
    • The location of these three clips is shown in the third picture.
  3. MacBook Unibody Model A1342 Rear Speaker Replacement, Battery: Schritt 3, Bild 1 von 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
    • It may be easier to use your fingernails to lift up on both sides of the connector.
  4. MacBook Unibody Model A1342 Rear Speaker Replacement, Rear Vent: Schritt 4, Bild 1 von 1
    • Remove the following screws from the optical drive side of the rear vent:
    • Two 10 mm T8 Torx
    • Two 5.2 mm Phillips
  5. MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 5, Bild 1 von 1
    • Remove the following screws from the port side of rear vent:
    • Two 10 mm T8 Torx
  6. MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 6, Bild 1 von 1
    • Carefully lift the rear vent out of the upper case.
  7. MacBook Unibody Model A1342 Rear Speaker Replacement, Rear Speaker Assembly: Schritt 7, Bild 1 von 1
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable connector up off the logic board.
  8. MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 8, Bild 1 von 1
    • Remove the following screws securing the right speaker assembly to the upper case:
    • One 12 mm Phillips screw.
    • One 3 mm Phillips screw.
  9. MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 9, Bild 1 von 1
    • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
  10. MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 10, Bild 1 von 2 MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 10, Bild 2 von 2
    • Pry the AirPort and Bluetooth antenna connectors (3 total) up off the AirPort/Bluetooth card.
    • De-route the long antenna from its channel in the rear speaker housing.
  11. MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 11, Bild 1 von 1
    • Use the flat end of a spudger to pry the rear speaker cable connector up off the logic board.
  12. MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 12, Bild 1 von 1
    • Remove the rear speaker assembly from the upper case.
  13. MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 13, Bild 1 von 2 MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 13, Bild 2 von 2
    • Carefully peel the AirPort/Bluetooth cable from its channel within the rear speaker assembly.
    • Use the flat end of a spudger to pry the AirPort/Bluetooth cable up off the rear speaker.
  14. MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 14, Bild 1 von 1
    • Remove three 3 mm Phillips screws securing the AirPort/Bluetooth board to the rear speaker assembly.
  15. MacBook Unibody Model A1342 Rear Speaker Replacement: Schritt 15, Bild 1 von 1
    • Lift the AirPort/Bluetooth board up off the rear speaker assembly.
  16. MacBook Unibody Model A1342 Rear Speaker Replacement, Rear Speaker: Schritt 16, Bild 1 von 1
    • Rear speaker remains.
Abschluss
24 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Nice tuto ! Helped me so fine.
Rudy Pierrat - Antwort
Perfect! That helps to keep older gear alive!
W. Scholz - Antwort
How did you guys place the rear speaker wire back in place?
Kim Sluyk - Antwort
hi everyone! iʻm about to replace the rear speaker on my late 2009 A1342, but i also need to replace both the left and right speakers as well. would someone please help me out? i hope i donʻt have to pull the logic board (i already did that on my mid 2012 A1284, and it was, ok, but i have more gray hairs now . . .).
Kahana - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 22
Letzte 30 Tage: 111
Insgesamt: 33,005
