Zum Hauptinhalt wechseln
Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel
Was du brauchst
  1. Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel, Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 1, Bild 1 von 2 Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel, Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 1, Bild 2 von 2
    • Slide the tab on the bottom of the mouse to release the top panel.
  2. Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 2, Bild 1 von 2 Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 2, Bild 2 von 2
    • Remove the top panel from the mouse.
  3. Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 3, Bild 1 von 1
    • Remove four 7mm Phillips #1 screws.
  4. Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 4, Bild 1 von 3 Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 4, Bild 2 von 3 Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 4, Bild 3 von 3
    • Use a spudger to pry the upper shell from the mouse at the cord entrance.
    • Move slowly. The upper case is connected to the mouse with delicate wires.
  5. Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 5, Bild 1 von 2 Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 5, Bild 2 von 2
    • Lift the scroll wheel out of the mouse.
  6. Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 6, Bild 1 von 1
    • Wiggle the USB cord free of the mouse.
    • Resist the temptation to yank the cord free. The wires are very delicate and soldered connections are weak
  7. Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 7, Bild 1 von 1
    • Remove one 3mm Phillips #1 screw.
    • The quantity and location of screws holding the board to the mouse depends on the manufacture date of this mouse. All screws should be easy to find.
  8. Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 8, Bild 1 von 3 Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 8, Bild 2 von 3 Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 8, Bild 3 von 3
    • Push the broken axle piece out of the socket.
  9. Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 9, Bild 1 von 2 Repairing Monoprice Super Slim Optical USB Mouse with DPI Adjustment Scroll Wheel: Schritt 9, Bild 2 von 2
    • Glue broken axle piece back onto the scroll wheel.
    • This repair will last only as long as your glue or epoxy holds. The axle will re-break with weak glue and heavy use. My axle survived several heavy use days, just long enough for Monoprice to send me a new mouse.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jeff Snyder
8.811 Reputation
4 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.259 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 849
