Einleitung
In the midst of the iPhone 4 craze, we became impatient and decided we needed to tear down a phone, you know, just to keep us in tip-top shape. And lo-and-behold, the Sony Ericsson Xperia X10 Mini E10i.
A big thanks to Brian at EDN for providing the phone for this teardown. Be sure to check out his Xperia X10 Mini Preview!
Was du brauchst
The Sony Ericsson Xperia X10 Mini E10i is the smaller version of the Sony Ericsson Xperia X10.
Tech Specs:
600 MHz Qualcomm MSM7227
256 MB RAM and 256 MB internal ROM (only 128 MB accessible)
2.6" color transflective TFT display with a resolution of 240 X 320 pixels.
5 Megapixel camera with autofocus
802.11 b/g Wireless + Bluetooth 2.1
The backside of the X10 Mini E10i is characterized by a smooth plastic rear case with openings for the camera, LED flash, and speaker.
The controls of the X10 Mini E10i are pretty standard.
The bottom of the X10 Mini E10i integrates a 3.5 mm headphone jack as well as a micro-USB port.
The top edge houses the power button.
The left side accommodates the volume and camera buttons, leaving the right side blank and featureless.
The 5.0 megapixel camera in the X10 Mini E10i features a 1X optical zoom with autofocus and a built-in LED flash.
The camera itself measures in at 8.8 x 9.1 x 6 mm.
A few quick pries with an iPod opening tool around the perimeter of the X10 Mini E10i and the rear case easily pops off to access the phone's innards.
A thumbnail is all that is needed to remove the microSD card from its housing in the inner case.
The simple design of the Mini E10 allows most components to plug directly into the logic board. The only exception is the external microSD card slot.
A single T5 Torx screw and a few plastic clips are all that secure the antenna assembly to the inner case.
A couple more T5 Torx screws secure the rear inner case and logic board to the rest of the X10 Mini E10i.
Disconnect the battery connector from the logic board with the flat end of a spudger.
Pry up the SIM card socket connector and remove the rear inner case from the the logic board.
The 3.7V 950 mAh Li-Polymer battery allows for 4 hours of talk time.
Measuring 40 x 35 x 5.5 mm and weighing in at a scant 18 grams, the X10 Mini E10i's battery provides up to 360 hours of 3G standby time.
The 5 MP camera, battery connector, vibrator motor, and speaker are densely packed on the logic board near the top of the phone.
After disconnecting the touchscreen connector, the logic board can be carefully pried out of its enclosure.
Rotate the logic board upward out of its cradle and use an iPod opening tool to disconnect the display data ribbon cable.
Big players on the board include:
A Qualcomm MSM7227 with 600 MHz application processing, 400 MHz modem processing, hardware accelerated 3D graphics, integrated Bluetooth 2.1 & GPS capabilities, and image/video encoding & decoding.
STMicroelectronics NANDCBR4N9
Skyworks SKY77336 GSM power amplifier module
Qualcomm PM7540 power management IC
Qualcomm RTR6285 UMTS RF transceiver with receive diversity and GPS
TriQuint TQM679002A WLAN Power Amplifier
Sensors near the top of the board face outward from the front of the phone near the earphone opening.
A proximity sensor turns off the touch screen when the phone is against your face.
A light sensor automatically adjusts the LCD brightness for optimal viewing in any lighting condition.
Further prying around the perimeter of the front panel assembly allows the LCD assembly to be separated from the front panel.
The digitizer is manufactured by Synaptics, with the main touch screen controller labeled as T1021A 1 0942 AC0P876.
A Samsung LMS255GF02 takes care of the Mini E10i's display needs.
And just like that, the dark deed has been done.
Thanks, Sony, for keeping it simple.
For more information on this little guy, check out EDN's Xperia X10 Mini Preview.
Keep an eye on our Teardown page for the arrival of the highly anticipated iPhone 4.
14 Kommentare
he great take apart, do you need to dissemble the whole phone to replace the power button cap?
More or less. It's been a while since I took this apart, but I think you'll have to take the logic board out (work up to step 9). Luckily, this phone is really straightforward to disassemble.
so you can't use BST-38 Size: (5.5 x 48 x 40 mm) battery instead that one you have on the picture (or BST-41 some sellers on Ebay say it is compatible) ???
Hi There
This is a fantastic guide, and has enabled me to get the battery out, does anyone know where on earth I can buy one of these, I have searched all the usual channels, google ebay etc, but can only find batteries for other models that look nothing like this.
Any help would be much appreciated
All the best - Trev
