Zum Hauptinhalt wechseln
Linksys WRT54GS v2 Power Connector Replacement
Was du brauchst
  1. Linksys WRT54GS v2 Power Connector Replacement, Front Case: Schritt 1, Bild 1 von 1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Linksys WRT54GS v2 Power Connector Replacement: Schritt 2, Bild 1 von 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Linksys WRT54GS v2 Power Connector Replacement: Schritt 3, Bild 1 von 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Linksys WRT54GS v2 Power Connector Replacement: Schritt 4, Bild 1 von 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Linksys WRT54GS v2 Power Connector Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Slide the board unit out and up.
  6. Linksys WRT54GS v2 Power Connector Replacement: Schritt 6, Bild 1 von 1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
  7. Linksys WRT54GS v2 Power Connector Replacement, Power Connector: Schritt 7, Bild 1 von 1
    • Turn the circuit board over.
    • Identify the solder connections on the board, marked in red.
  8. Linksys WRT54GS v2 Power Connector Replacement: Schritt 8, Bild 1 von 1
    • Desolder the connection by following iFixit's guide to repairing soldered connections: Wie man Lötverbindungen herstellt und entlötet.
    • Remove the Power Connector from the board.
    • Insert the replacement power port and resolder the connectors.
Abschluss
Alex Do
51 Reputation
1 Anleitung geschrieben
Cal Poly, Team 3-4, Regan Fall 2011 Mitglied von Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 1,846
