Zum Hauptinhalt wechseln
Acer Aspire One D255E RAM Replacement
Was du brauchst
  1. Acer Aspire One D255E RAM Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E RAM Replacement: Schritt 2, Bild 1 von 2 Acer Aspire One D255E RAM Replacement: Schritt 2, Bild 2 von 2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E RAM Replacement: Schritt 3, Bild 1 von 3 Acer Aspire One D255E RAM Replacement: Schritt 3, Bild 2 von 3 Acer Aspire One D255E RAM Replacement: Schritt 3, Bild 3 von 3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E RAM Replacement: Schritt 4, Bild 1 von 1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
  5. Acer Aspire One D255E RAM Replacement, Back Panel: Schritt 5, Bild 1 von 2 Acer Aspire One D255E RAM Replacement, Back Panel: Schritt 5, Bild 2 von 2
    • Unscrew seven 1.2 mm Phillips #1 screws from the back of the device
  6. Acer Aspire One D255E RAM Replacement: Schritt 6, Bild 1 von 2 Acer Aspire One D255E RAM Replacement: Schritt 6, Bild 2 von 2
    • Unscrew eight more 1.2 mm Phillips #1 screws from the front of the computer.
  7. Acer Aspire One D255E RAM Replacement: Schritt 7, Bild 1 von 3 Acer Aspire One D255E RAM Replacement: Schritt 7, Bild 2 von 3 Acer Aspire One D255E RAM Replacement: Schritt 7, Bild 3 von 3
    • Using a spudger carefully push though the hole to dislodge the panel on the back of the device then remove the panel by hand.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  8. Acer Aspire One D255E RAM Replacement, RAM: Schritt 8, Bild 1 von 3 Acer Aspire One D255E RAM Replacement, RAM: Schritt 8, Bild 2 von 3 Acer Aspire One D255E RAM Replacement, RAM: Schritt 8, Bild 3 von 3
    • Using your hands pull apart the two clips holding the RAM in then pull out the RAM.
    • It uses (DDR3) 204pin PC3-10600 1333MHz DDR3 SO-DIMM Memory Modules
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Brian
1.248 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 16-8, Bhusal Spring 2016
UMASSD-BHUSAL-S16S16G8
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 26
Insgesamt: 4,517
