Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die die grundständige Anleitung beinhaltet.
Schritt 1 übersetzen
Schritt 1
Upper Main Flex Connector Disconnect
Use a pair of tweezers to unhinge and remove the small metal shield that covers the main and interconnect flex cable connectors.
[title] Upper Main Flex Connector Disconnect | |
- | [* black] Use a pair of tweezers to unhinge and remove the small metal shield that covers the main and interconnect flex cable connectors. |
+ | [* black] Use a pair of [product|IF145-020|tweezers] to unhinge and remove the small metal shield that covers the main and interconnect flex cable connectors. |
[* icon_note] The metal shield is held in place by mild adhesive. In case you're having trouble removing it, you can apply [guide|25705|a heated iOpener|new_window=true] to loosen the adhesive underneath. |
