Zum Hauptinhalt wechseln
iPad 6 Wi-Fi LCD Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 11 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 5
iPad 6 Wi-Fi LCD Replacement: Schritt 0, Bild 1 von 3 iPad 6 Wi-Fi LCD Replacement: Schritt 0, Bild 2 von 3 iPad 6 Wi-Fi LCD Replacement: Schritt 0, Bild 3 von 3
  • Remove the single 2.3 mm Phillips #000 screw securing the battery connector to the logic board.
  • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
  • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
  • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
  • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
  • Leave the battery blocker in place as you work.
Hier Übersetzung einfügen
