Zum Hauptinhalt wechseln
iPhone 8 Plus 배터리 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Koreanisch
Schritt 5
iPhone 8 Plus Battery Replacement: Schritt 0, Bild 1 von 2 iPhone 8 Plus Battery Replacement: Schritt 0, Bild 2 von 2
  • If any of the adhesive strips broke off and the battery remains stuck to the rear case, remove it by adding a few drops of isopropyl alcohol (90% or greater) underneath the battery near the stuck strip(s). After about a minute, gently lift the battery.
  • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
  • If the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. This will help soften the adhesive.
  • Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
  • Alternatively, thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
  • Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. Do not deform or damage the battery.
  • To protect your fingers, wear gloves or wrap the string ends around a tool (such as the two screwdriver handles shown in the image).
접착 스트립이 끊어지고 배터리가 후면 케이스에 붙어 있으면 iOpener를 준비하거나 헤어 드라이기를 사용하여 후면 케이스 배터리 바로 뒤를 가열하세요.
후면 케이스가 편안하게 만질 수 없을 정도로 약간 뜨거워질 때까지만 iPhone을 가열하세요. iPhone을 과열하지 마세요. 실수로 배터리가 점화될 수 있습니다.
iPhone을 뒤집어 놓고 배터리 아랫면에 강한 줄(치실 또는 얇은 기타 줄)을 끼우세요.
톱질 동작으로 배터리 길이를 따라 끈을 좌우로 잡아 당겨 접착제를 분리하세요. 배터리를 변형 또는 손상시키지 마세요.
손가락을 보호하기 위해 장갑을 끼거나 도구에 줄을 감싸주세요 (이미지에 나온 스크루드라이버 두 개 처럼).
iPhone 배터리를 들어 올리기 위해 비집는 도구를 사용하는 경우 매우 조심하세요. 조심하지 않으면 배터리 바로 아래있는 리본 케이블 또는 무선 충전 코일이 손상될 수 있습니다.
-[* black] If any of the adhesive strips broke off and the battery remains stuck to the rear case, [guide|11677|prepare an iOpener|new_window=true] or use a hair dryer to heat the rear case directly behind the battery. This will help soften the adhesive.
+[* icon_note] If any of the adhesive strips broke off and the battery remains stuck to the rear case, remove it by adding a few drops of isopropyl alcohol (90% or greater) underneath the battery near the stuck strip(s). After about a minute, gently lift the battery.
+ [* icon_caution] Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
+ [* icon_caution] If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
+[* icon_note] If the battery remains stuck to the rear case, [guide|11677|prepare an iOpener|new_window=true] or use a hair dryer to heat the rear case directly behind the battery. This will help soften the adhesive.
[* icon_caution] Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
-[* black] Flip the iPhone back over and thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
-[* black] Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. ***Do not deform or damage the battery.***
- [* black] To protect your fingers, wear gloves or wrap the string ends around a tool (such as the two screwdriver handles shown in the image).
-[* icon_caution] If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
+[* icon_note] Alternatively, thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
+ [* black] Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. ***Do not deform or damage the battery.***
+ [* icon_caution] To protect your fingers, wear gloves or wrap the string ends around a tool (such as the two screwdriver handles shown in the image).
