Zum Hauptinhalt wechseln
맞춤형 접착 시트 사용법
Englisch
Koreanisch
Schritt 9 übersetzen
Schritt 9
How to Use a Pre-Cut Adhesive Sheet: Schritt 0, Bild 1 von 2 How to Use a Pre-Cut Adhesive Sheet: Schritt 0, Bild 2 von 2
  • Apply even pressure over the whole adhesion surface for at least 30 seconds to strengthen the bond.
  • For maximum bond strength on external-facing components (like displays and covers), you can leave the adhesive under pressure overnight.
  • Leaving the phone under a stack of books is a good way to do this—just make sure the books apply even pressure to the entire bond. You may need some kind of spacer to allow the books to lay flat.
  • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
접착력을 강화하기 위해 접착 표면 전체에 30초 이상 균일한 압력을 가하세요.
(디스플레이 및 커버 같은) 외부 부품의 접착 강도를 극대화하려면 접착제에 밤새도록 압력을 가하세요.
휴대폰 위로 책을 쌓아두는 것이 좋은 방법입니다—책이 접착면 전체에 고르게 압력을 가하도록 하세요. 책을 평평하게 놓으려면 일종의 스페이서가 필요할 수 있습니다.
[* black] Apply even pressure over the whole adhesion surface for at least 30 seconds to strengthen the bond.
[* black] For maximum bond strength on external-facing components (like displays and covers), you can leave the adhesive under pressure overnight.
[* black] [https://d3nevzfk7ii3be.cloudfront.net/igi/CvgAu6AgiFyScFWV.huge|Leaving the phone under a stack of books|new_window=true] is a good way to do this—just make sure the books apply even pressure to the entire bond. You may need some kind of spacer to allow the books to lay flat.
+ [* icon_note] Alternatively, you can use [guide|142291|screen vice clamps] around the perimeter of your device to set the new adhesive.
