Zum Hauptinhalt wechseln
Samsung Galaxy A3 (2017) Display austauschen
Englisch
Deutsch
Schritt 4
Samsung Galaxy A3 (2017) Display Replacement: Schritt 0, Bild 1 von 2 Samsung Galaxy A3 (2017) Display Replacement: Schritt 0, Bild 2 von 2
  • The screen's flex cable is located right behind the volume buttons, and may interfere with your cutting tool.
  • After cutting the adhesive on all sides of the phone, insert a plastic card beneath the display assembly to loosen any remaining adhesive behind it.
Das Flachbandkabel des Bildschirms befindet sich direkt hinter den Lautstärkeregler und kann deinem Schneidewerkzeug in die Quere kommen.
Schiebe, sobald der Kleber an allen Seiten aufgetrennt ist, eine Plastikkarte unter die Displayeinheit, um alle Klebereste dahinter zu lösen.
[* icon_caution] The screen's flex cable is located right behind the volume buttons, and may interfere with your cutting tool.
-[* black] After cutting the adhesive on all sides of the phone, insert a plastic card beneath the display assembly to loosen any remaining adhesive behind it.
+[* black] After cutting the adhesive on all sides of the phone, insert a [product|IF145-101|plastic card] beneath the display assembly to loosen any remaining adhesive behind it.
