Zum Hauptinhalt wechseln
LG G6 Battery Replacement
Englisch
Koreanisch
Schritt 3 übersetzen
Schritt 3
LG G6 Battery Replacement: Schritt 0, Bild 1 von 2 LG G6 Battery Replacement: Schritt 0, Bild 2 von 2
  • The battery is held in place with some fairly strong adhesive. If you have difficulty removing your battery, or if it starts to deform as you pull it out, you can try these other removal tricks:
  • Prepare an iOpener and apply it to the screen opposite where the battery sits. The heat will help soften the adhesive holding the battery down. Do not apply the iOpener or any other form of heat directly to the battery.
  • Apply some high-concentration isopropyl alcohol or adhesive remover along the bottom of the battery and then tilt the phone so the liquid will run along the bottom of the battery and weaken the adhesive. Then wait a few minutes and try removal again.
  • Carefully slide the flat end of a spudger under the battery to slice through the adhesive and lever the battery out of the phone.
  • To install a new battery, clean any residual adhesive from the phone and use some Tesa tape to hold the new battery in place. Do not reuse your battery if it is wrinkled or deformed in any way.
Hier Übersetzung einfügen
