Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 6
First things first—let's replace the one openly replaceable component! The silicone eartips snap off and back on with a satisfying click. Most silicone tips slide over a groove on the outside of the earbud. Apple's design uses some fancy engineering and (surprise!) isn't compatible with any typical silicone tips. That means you won't be able to use your favorite aftermarket tips with these, but Apple at least made their official replacement tips just $4 for when your tips tear or get lost.
  • First things first—let's replace the one openly replaceable component! The silicone eartips snap off and back on with a satisfying click.
  • Most silicone tips slide over a groove on the outside of the earbud. Apple's design uses some fancy engineering and (surprise!) isn't compatible with any typical silicone tips.
  • That means you won't be able to use your favorite aftermarket tips with these, but Apple at least made their official replacement tips just $4 for when your tips tear or get lost.
  • As much as we like standardized parts, these fancy tips do provide the benefit of a larger opening for sound than we'd normally see in an earbud.
  • Now that the soft silicone is out of the way, it's time to bring out the big (heat) guns. We don't want to be too presumptuous, but we think we know what we're about to get into...
  • A little pressure from the trusty vise opens up the seal around the head of the AirPod, and our halberd spudger eases the Pod open slightly further.
  • This definitely looked easier in the product video.
Als Allererstes ersetzen wir die Komponente, die ganz offenkundig austauschbar ist! Die Silikontips lassen sich leicht abziehen und rasten mit einem befriedigenden Klick wieder ein.
Die meisten Silikontips werden über eine Rille auf der Außenseite der Ohrhörer gesetzt. Das Apple-Design nutzt eine originelle Konstruktion und (Überraschung!) ist daher nicht kompatibel mit handelsüblichen Silikontips.
Das heißt, dass du deine Lieblings-Aftermarket-Tips hier nicht benutzen kannst, aber wenigstens kosten die Ersatz-Tips von Apple nur $4, falls deine kaputt gehen oder du sie verlierst.
So sehr wir standardisierte Ersatzteile mögen, diese schicken Tips haben den Vorteil, dass sie eine größere Öffnung für den Ton bieten, als sie normalerweise in Ohrhörern zu finden ist.
Das weiche Silikon ist erledigt, jetzt fahren wir die schweren Geschütze auf. Wir wollen ja nicht eingebildet klingen, aber wir glauben zu wissen was jetzt auf uns zukommt ...
Mit etwas Druck von unserer zuverlässigen Schraubzwinge können wir die Versiegelung um den Kopf des AirPod herum öffnen, und mit unserem Hellebarden-Spudger öffnen wir den Pod noch ein kleines bisschen weiter.
Im Produktvideo sah das definitiv einfacher aus.
