Schritt 1 übersetzen
Schritt 1
Before installing new adhesive, thoroughly clean the display assembly and the frame of all residue.
Use tweezers to pull up sections of tape residue.
Use an opening tool or a spudger to scrape residue off. You can use high concentration (over 90%) isopropyl alcohol to soften the adhesive.
Remove the residue by wiping in one direction to prevent smearing.
[* black] Before installing new adhesive, thoroughly clean the display assembly and the frame of all residue. | |
- | [* black] Use tweezers to pull up sections of tape residue. |
+ | [* black] Use [product|IF145-020|tweezers] to pull up sections of tape residue. |
[* black] Use an opening tool or a spudger to scrape residue off. You can use high concentration (over 90%) isopropyl alcohol to soften the adhesive. | |
[* black] Remove the residue by wiping in one direction to prevent smearing. | |
[* icon_caution] Do not scrape with a metal tool, or you will scratch the display assembly's surface. |
