Zum Hauptinhalt wechseln
Xbox Series X Optical Drive Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Koreanisch
Schritt 7
Xbox Series X Optical Drive Replacement, Desolder the two wires: Schritt 0, Bild 1 von 2 Xbox Series X Optical Drive Replacement, Desolder the two wires: Schritt 0, Bild 2 von 2
  • Use a soldering iron to desolder the red wire in the corner of the optical drive board.
  • Then, desolder the adjacent black wire. Use a pair of blunt tweezers to hold and pull away the wires from the board.
  • Follow general soldering safety guidelines such as wearing eye protection, working in a well-ventilated area, and washing your hands with soap and water after soldering.
  • Excessive heat may damage electrical components. Don't apply the soldering iron to the board for long periods of time.
  • When you install the original board into the replacement optical drive, solder the red wire to the solder pad labeled R. Solder the black wire to the solder pad labeled B.
Hier Übersetzung einfügen
