Zum Hauptinhalt wechseln
Microsoft Surface Pro 6 Opening Procedure
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 13 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 13
Microsoft Surface Pro 6 Opening Procedure: Schritt 0, Bild 1 von 3 Microsoft Surface Pro 6 Opening Procedure: Schritt 0, Bild 2 von 3 Microsoft Surface Pro 6 Opening Procedure: Schritt 0, Bild 3 von 3
  • Once you cut the adhesive over the antennas (8.5 inches, or 22 cm, away from the left edge), slide the pick the rest of the way along the top edge of the surface and round the top right corner to slice through any remaining adhesive.
일단 안테나 위의 접착제를 자르고 (왼편 가장자리에서 8.5인치, 또는 22cm, 떨어져 있음), 나머지 surface 상단 가장자리를 따라서 픽을 밀고 오른편 상단 모서리를 따라 돌아서 나머지 접착제를 자르세요.
