Zum Hauptinhalt wechseln
Mackie CR3 CR4 L/R Speaker Selector Bypass
Englisch
Koreanisch
Schritt 2
Mackie CR3 CR4 L/R Speaker Selector Bypass, Examine your board: Schritt 0, Bild 1 von 3 Mackie CR3 CR4 L/R Speaker Selector Bypass, Examine your board: Schritt 0, Bild 2 von 3 Mackie CR3 CR4 L/R Speaker Selector Bypass, Examine your board: Schritt 0, Bild 3 von 3
Examine your board
  • Arrange things so you have easy access to the underside of the circuit board, and the back panel to the right.
  • The contact points we need to work on are the bottom 4 pins in the cluster of 6 pins, directly left of the switch, on the back of the circuit board.
  • For the Powered speaker on the RIGHT, connect the top and bottom connections in that group of 4. Two parallel lines. ||
  • For the Powered speaker on the LEFT, cross the top and bottom connections in that group of 4. Two intersecting lines. X
Hier Übersetzung einfügen
