Zum Hauptinhalt wechseln
How to Fix the C6 Error for a Pressure Cooker
Englisch
Koreanisch
Schritt 7
How to Fix the C6 Error for a Pressure Cooker, Diagnose the C6L error: Schritt 0, Bild 1 von 3 How to Fix the C6 Error for a Pressure Cooker, Diagnose the C6L error: Schritt 0, Bild 2 von 3 How to Fix the C6 Error for a Pressure Cooker, Diagnose the C6L error: Schritt 0, Bild 3 von 3
  • This step shows how to test the low pressure sensor more extensively. You should check this sensor if you get a C6L error.
  • Disconnect the low pressure sensor by squeezing its circuit board connector to disengage the lock, then pull straight up.
  • Attach a multimeter lead to both exposed ends of the sensor wires, making sure the leads don't touch each other.
  • Set the meter to resistance/continuity and test for continuity, when the sensor is resting, and when it's depressed.
  • The meter should show low resistance/continuous when the sensor is resting, and no continuity when the sensor's depressed.
Hier Übersetzung einfügen
