Zum Hauptinhalt wechseln
How to Fix the C6 Error for a Pressure Cooker
Englisch
Koreanisch
Schritt 8
How to Fix the C6 Error for a Pressure Cooker, Clean the sensor contacts: Schritt 0, Bild 1 von 2 How to Fix the C6 Error for a Pressure Cooker, Clean the sensor contacts: Schritt 0, Bild 2 von 2
  • If your tests suggest that you may have dirty contacts, or you suspect the contacts have fused, follow the next steps to remove the sensors to clean them.
  • Use a Phillips screwdriver to remove the screw securing the sensors to the pressure cooker.
  • This screw can be very tight. Be sure to use the right sized screwdriver to avoid stripping it.
  • Lift the sensor assembly out of its recess.
Hier Übersetzung einfügen
