Zum Hauptinhalt wechseln
Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement
Englisch
Koreanisch
Schritt 6
Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement: Schritt 0, Bild 1 von 3 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement: Schritt 0, Bild 2 von 3 Nintendo Switch Micro SD Card Reader (FPC Connector Socket) Replacement: Schritt 0, Bild 3 von 3
  • Using the heat gun apply 400°C heat to the connector socket for 30 seconds to loosen the flux.
  • Remove the metal cover plate
  • Carefully remove the FPC connector socket using the tweezers.
  • Be careful with the heat gun in order to prevent harm to other parts or yourself
  • It is encouraged to wear heat-resistant gloves and to cover other components with aluminum foil or another metal casing.
Hier Übersetzung einfügen
