Zum Hauptinhalt wechseln
Front-Panel-Einheit ausbauen
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 15 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 7 übersetzen
Schritt 7
Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 1 von 3 Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 2 von 3 Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 3 von 3
  • Remove the front panel assembly.
  • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
  • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
  • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
  • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
  • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
  • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
Entferne die Front-Panel-Einheit.
Trenne eventuelle Kleberreste zwischen der Front-Panel-Einheit und dem Rahmen mit einem Plektrum auf.
Wenn am Touchscreen dann noch "Geister" oder "Phantom"-Effekte auftreten, kann dies durch Aufkleben von sehr dünnen Isolierband , wie z.B. Kapton (Polyimid) Band an den markierten Stellen auf der Rückseite des Panels gelöst werden. Ersatzteile von iFixit sind schon entsprechend ausgerüstet, hier sollte das nicht notwendig sein.
Ohne die richtige Isolierung können diese Stellen in Kontakt zu anderen Bauteilen kommen und diese Fehlfunktion verursachen.
Diese Isolierung ist mit bloßem Auge nicht sichtbar und unterscheidet sich von den Staubschutzstreifen aus Schaumstoff, so wie sie in vielen iPads anzutreffen sind.
Bevor du beim Zusammenbau das neue Display einbaust, musst du alle Kleberreste vom iPad entfernen und die Klebestellen mit hochkonzentriertem (mindestens 90%igem) Isopropylalkohol und einem fusselfreien Tuch reinigen. Dadurch wird das iPad für den neuen Kleber vorbereitet; er kann dann besser haften.
Teste alle Funktionen des iPads und befestige vorgestanzte Klebestreifen auf der Rückseite des Displays. Unsere Anleitung für Displayklebestreifen hilft dir dabei, bevor du das Display endgültig festklebst.
