Zum Hauptinhalt wechseln
스크린 분리하기
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 15 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 14
Screen Removal, Remove the display cable bracket: Schritt 0, Bild 1 von 3 Screen Removal, Remove the display cable bracket: Schritt 0, Bild 2 von 3 Screen Removal, Remove the display cable bracket: Schritt 0, Bild 3 von 3
  • The display cable bracket is secured with metal clips.
  • Use tweezers to bend the bottom side of the bracket upwards, releasing the metal clip.
  • Remove the display cable bracket.
  • During reassembly, insert the top side of the bracket first before pressing down the other side. Failure to do so could result in sparks and logic board damage.
디스플레이 케이블 브래킷은 금속 클립으로 고정되어 있습니다.
핀셋을 사용하여 브래킷의 아래쪽을 위로 구부려 금속 클립을 풀어주세요.
디스플레이 케이블 브래킷을 분리하세요.
재조립할 때, 브래킷의 상단을 먼저 끼운 다음 반대편을 아래로 누르세요. 아니면 불꽃이 튀거나 로직 보드를 손상할 수 있습니다.
[title] Remove the display cable bracket
[* icon_note] The display cable bracket is secured with metal clips.
-[* black] Use tweezers to bend the bottom side of the bracket upwards, releasing the metal clip.
+[* black] Use [product|IF145-020|tweezers] to bend the bottom side of the bracket upwards, releasing the metal clip.
[* black] Remove the display cable bracket.
[* icon_reminder] During reassembly, ***insert the top side of the bracket first*** before pressing down the other side. Failure to do so could result in sparks and logic board damage.
