Zum Hauptinhalt wechseln
Opening Procedure (Prereq)
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 16 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 5
Opening Procedure (Prereq): Schritt 0, Bild 1 von 2 Opening Procedure (Prereq): Schritt 0, Bild 2 von 2
  • Wait one minute to give the adhesive a chance to release and present an opening gap.
  • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
  • For complete instructions on how to use a hair dryer, check out this guide.
  • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
  • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
  • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
  • Skip the next step.
Hier Übersetzung einfügen
