Zum Hauptinhalt wechseln
Samsung Galaxy S22 Ultra 후면 커버 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 10 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 6
Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: Schritt 0, Bild 1 von 3 Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: Schritt 0, Bild 2 von 3 Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: Schritt 0, Bild 3 von 3
  • Insert a second opening pick at the bottom right corner.
  • Angle the pick upward to match the curved edge and rotate it around the bottom right corner.
  • Be careful while slicing around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
하단 오른편 모서리에 두 번째 여는 픽을 끼우세요.
굽은 가장자리와 맞도록 픽을 위를 향해 기울이고 하단 오른편 모서리를 따라서 밀어주세요.
유리는 깨지기가 매우 쉽기 때문에 모서리를 돌아서 자를 때 조심하세요. 유리가 깨지지 않도록 천천히 작업하세요.
