Zum Hauptinhalt wechseln
Samsung Galaxy S22 Ultra 후면 커버 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 10 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 12
Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: Schritt 0, Bild 1 von 3 Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: Schritt 0, Bild 2 von 3 Samsung Galaxy S22 Ultra Back Cover Replacement, Separate the corner adhesive: Schritt 0, Bild 3 von 3
  • Insert an opening pick in the gap at the top right edge.
  • Angle the pick upward to match the curved edge and rotate it around the top right corner.
  • Be careful while slicing around the corners, as the glass is very fragile here. Work slowly to avoid cracking the glass.
상단 오른편 가장자리 틈에 여는 픽을 끼우세요.
굽은 가장자리와 맞도록 픽을 위를 향해 기울이고 상단 오른편 모서리를 따라서 밀어주세요.
유리는 깨지기가 매우 쉽기 때문에 모서리를 돌아서 자를 때 조심하세요. 유리가 깨지지 않도록 천천히 작업하세요.
