Zum Hauptinhalt wechseln
Logitech G Pro X Superlight 여는 방법
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 4
How to Open Your Logitech G Pro X Superlight, Disconnect the shell cables: Schritt 0, Bild 1 von 3 How to Open Your Logitech G Pro X Superlight, Disconnect the shell cables: Schritt 0, Bild 2 von 3 How to Open Your Logitech G Pro X Superlight, Disconnect the shell cables: Schritt 0, Bild 3 von 3
  • Use the point of a spudger to lift the locking flap on the top shell ZIF connector.
  • Use tweezers to gently pull the cable straight out of its socket.
  • During reassembly, insert the cable into its socket up to the white line before flipping down the locking flap.
스퍼저의 끝을 사용하여 상단 쉘의 ZIF 커넥터 잠금 플랩을 들어 올리세요.
핀셋을 사용하여 케이블을 소켓에서 조심스럽게 똑바로 잡아당겨 빼내세요.
재조립할 때, 케이블을 흰색 선까지 소켓에 끼운 다음 잠금 덮개를 아래로 젖히세요.
