Zum Hauptinhalt wechseln
HP Pavilion 14-cf0014dx Touchpad Button Board Replacement
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
HP Pavilion 14-cf0014dx Touchpad Button Board Replacement: Schritt 0, Bild 1 von 1
  • Use a Phillips #0 screwdriver to remove the two 2.7 mm screws that secure the touchpad button board.
  • Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connectors securing the two ribbon cables connected to the button board.
  • Use the widest tool possible to avoid damaging the delicate hinge pins.
  • Once the flap is in the unlocked position, use tweezers or your fingers to gently pull the cable out of its socket by the tab.
  • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
Hier Übersetzung einfügen
