Zum Hauptinhalt wechseln
Rozia HQ242 Trimmer Spring Replacement
Englisch
Koreanisch
Schritt 4
Rozia HQ242 Trimmer Spring Replacement: Schritt 0, Bild 1 von 3 Rozia HQ242 Trimmer Spring Replacement: Schritt 0, Bild 2 von 3 Rozia HQ242 Trimmer Spring Replacement: Schritt 0, Bild 3 von 3
  • Align the flat U-shaped end of the spring to the notch on the trimmer.
  • Gently pinch the two legs of the spring with your thumb and index finger, aligning them to point towards the front of the trimmer at a 45-degree angle, then drop it into the slot.
  • Once it is successfully in, carefully let go. If it falls off the notch, you will have to wedge it out and try again. This may take multiple attempts.
  • Make sure that the spring is securely resting on the notch, or the trimmer may not function properly!
Hier Übersetzung einfügen
