Zum Hauptinhalt wechseln
Samson G-Track Pro Teardown
Englisch
Deutsch
Schritt 7
Samson G-Track Pro Teardown, Lifting Sticker: Schritt 0, Bild 1 von 3 Samson G-Track Pro Teardown, Lifting Sticker: Schritt 0, Bild 2 von 3 Samson G-Track Pro Teardown, Lifting Sticker: Schritt 0, Bild 3 von 3
Lifting Sticker
  • The part surrounding the jacks is a thick sticker. The tip of a hobby knife is the easiest way to lift the sticker. However, it is very likely to cause small scratches in the surrounding area. A small piece of tape beneath the blade can help protect the paint somewhat.
  • Once there is enough room, insert a plastic tool like a spudger or guitar pick to prevent further damage.
  • Gently pry the sticker so that the 3.5mm jack end can be lifted.
  • While fairly robust, the sticker can crease if bent too far. Try to keep the angle less than 45 degrees.
Hier Übersetzung einfügen
