Zum Hauptinhalt wechseln
iPhone 16 Pro Max Display tauschen
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 5
iPhone 16 Pro Max Screen Installation: Schritt 0, Bild 1 von 1
  • Grasp the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
  • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
  • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
Löse die große Trägerfolie des Ersatzklebestreifens ab. Beginne damit an der Unterkante.
Normalerweise befindet sich eine große Zuglasche an der Unterkante.
-[* black] Begin peeling the large backing from your replacement adhesive, starting from the bottom edge.
- [* red] You'll usually find a large tab of some kind on the bottom edge.
+[* black] Grasp the tab in the corner of the adhesive sheet and peel the liner to expose ***a third ***of the adhesive.
+ [* icon_caution] The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
+ [* icon_note] If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
