Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Schritt 6 übersetzen
Schritt 6
Carefully align the exposed edge of the adhesive strip with the corresponding edge of your iPhone's frame.
When it's correctly aligned, gently press the exposed adhesive strip into place.
- | [* icon_note] Before applying the adhesive, make sure your iPhone's battery connector lays flat so it doesn't press against the blue release liner. It's okay to temporarily reconnect the battery if needed—just be sure to disconnect it again before installing the display. |
- | [* black] Carefully align the exposed lower edge of the adhesive strip with the bottom edge of your iPhone's case. |
- | [* icon_caution] Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive. |
- | [* black] When it's correctly aligned, gently press the exposed lower adhesive strip into place. |
+ | [* black] Carefully align the exposed edge of the adhesive strip with the corresponding edge of your iPhone's frame. |
+ | [* icon_caution] Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive. |
+ | [* black] When it's correctly aligned, gently press the exposed adhesive strip into place. |
