Zum Hauptinhalt wechseln
Pyrex Professional Kitchen Timer and Thermometer Teardown
Englisch
Koreanisch
Schritt 2
Pyrex Professional Kitchen Timer and Thermometer Teardown: Schritt 0, Bild 1 von 2 Pyrex Professional Kitchen Timer and Thermometer Teardown: Schritt 0, Bild 2 von 2
  • Carefully pull the back off. Keep an eye out for the C/F switch that is held in place by the bottom cover. Don't pull too hard or you may break the wires from the battery compartment.
  • Set the plastic C/F switch in a safe place as it bounces away easy and is small.
  • If you need to completely separate the cover from the case you will need to unsolder the wires to the battery compartment.
  • To reassemble, put the C/F switch in its spot and press the cover back on being careful not to pinch wires. Reinstall the 4 screws.
Hier Übersetzung einfügen
