Zum Hauptinhalt wechseln
iPhone 5s 전면 패널 어셈블리 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 32 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 10
iPhone 5s Front Panel Assembly Replacement: Schritt 0, Bild 1 von 2 iPhone 5s Front Panel Assembly Replacement: Schritt 0, Bild 2 von 2
  • During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
  • Slide the top of the bracket over the Touch ID cable connector from left to right.
  • Alternatively, lay the bracket directly over the connector. The edge with the "leg" will prop the bracket up at a slight angle, and the opposite edge must be between the cable connector and the metal tab near the battery. With the edge of a spudger flat against the bracket, apply gentle downward pressure to snap in the back and front clasps.
재조립할 때 Touch ID 케이블 브래킷을 다시 설치해야합니다. 브래킷 상단을 금속 탭 앞쪽 배터리와 Touch ID 케이블 커넥터 사이에서 밀어야 합니다. 하단은 커넥터 위로 고정해야 합니다.
브래킷 상단을 Touch ID 케이블 커넥터 위로 왼편에서 오른편으로 미세요.
[* icon_reminder] During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
[* icon_reminder] Slide the top of the bracket over the Touch ID cable connector from left to right.
+[* icon_note] Alternatively, lay the bracket directly over the connector. The edge with the "leg" will prop the bracket up at a slight angle, and the opposite edge must be between the cable connector and the metal tab near the battery. With the edge of a spudger flat against the bracket, apply gentle downward pressure to snap in the back and front clasps.
