Zum Hauptinhalt wechseln
iPhone 5s 전면 패널 어셈블리 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 32 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 8
iPhone 5s Front Panel Assembly Replacement: Schritt 0, Bild 1 von 2 iPhone 5s Front Panel Assembly Replacement: Schritt 0, Bild 2 von 2
  • Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
  • Pull the plastic nub to release the vacuum seal on the suction cup.
  • Remove the suction cup from the screen.
끊어지기 쉬운 리본 케이블 여럿이 연결되어 있으므로 전면 패널 어셈블리를 후면 패널에서 완전히 분리하지 마세요.
플라스틱 너브를 당겨 흡입 컵의 진공 씰을 해제하세요.
스크린에서 흡입 컵을 분리하세요.
