Zum Hauptinhalt wechseln
Teenage Engineering OP-1 Connector Board Replacement
Englisch
Koreanisch
Schritt 2
Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: Schritt 0, Bild 1 von 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: Schritt 0, Bild 2 von 3 Teenage Engineering OP-1 Connector Board Replacement, Remove Connector Board: Schritt 0, Bild 3 von 3
  • Disconnect the flex connector by lifting it up with a spudger.
  • Remove the three Phillips screws. Do not lose the washer at the bottom screw.
  • Take out the connector board.
  • Make sure to keep the black rubber pad underneath the board.
Hier Übersetzung einfügen
