Zum Hauptinhalt wechseln
Canon EOS Rebel T4i Motherboard ersetzen
Englisch
Deutsch
Schritt 12 übersetzen
Schritt 12
Canon EOS Rebel T4i Motherboard Replacement: Schritt 0, Bild 1 von 2 Canon EOS Rebel T4i Motherboard Replacement: Schritt 0, Bild 2 von 2
  • Remove the following screws from the motherboard using the JIS #00 screwdriver:
  • Two 3.9mm JIS screws.
  • Three 2.9mm JIS screws
  • Gently pull the motherboard out of the camera.
Entferne die folgenden Schrauben mit einem Kreuzschlitzschraubendreher (Phillips #00) vom Motherboard.
Zwei 3,9 mm Kreuzschlitzschrauben
Drei 2,9 mm Kreuzschlitzschrauben
Ziehe das Motherboard vorsichtig aus der Kamera heraus.
-[* black] Remove the following screws from the motherboard using the Phillips #00 screwdriver:
- [* orange] Two 3.9mm Phillips head screws.
- [* yellow] Three 2.9mm Phillips head screws
+[* black] Remove the following screws from the motherboard using the JIS #00 screwdriver:
+ [* orange] Two 3.9mm JIS screws.
+ [* yellow] Three 2.9mm JIS screws
[* black] Gently pull the motherboard out of the camera.
