Zum Hauptinhalt wechseln
케이블 커넥터 인식 및 연결 해제
Englisch
Koreanisch
Schritt 1 übersetzen
Schritt 1
Recognizing & Disconnecting Cable Connectors, ZIF Connectors: Schritt 0, Bild 1 von 3 Recognizing & Disconnecting Cable Connectors, ZIF Connectors: Schritt 0, Bild 2 von 3 Recognizing & Disconnecting Cable Connectors, ZIF Connectors: Schritt 0, Bild 3 von 3
ZIF Connectors
  • Zero insertion force (ZIF) connectors are often used to secure delicate ribbon cables of many sizes. A hinged locking flap runs across the top of the socket, and the cable is inserted on one of the long edges.
  • To disconnect the cable, use a spudger, opening tool, or a clean fingernail to flip up the locking flap—this is the unlocked position.
  • Use the widest tool possible to avoid damaging the delicate hinge pins.
  • Once the flap is in the unlocked position, use tweezers or your fingers to gently pull the cable out of its socket.
  • If the cable has a pull tab, use it to grip the cable. You may damage the cable by gripping it directly.
  • Some cables may have small "arms" or notches that help secure them. If this is the case, you'll need to lift the cable to free it and then pull it out.
  • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
  • Some cables (like the one pictured) may have a line that marks the edge of the connection area. Make sure you insert the cable so the line is flush with the edge of the socket.
ZIF (Zero Insertion Force) 커넥터는 종종 초보자에게 문제가 됩니다. ZIF 커넥터는 FFC (Flat Flex Cable) 또는 FPC (Flexible Printed Circuit) 케이블 처럼 부서지기 쉬운 리본 케이블을 고정하는 데 사용됩니다.
이름에서 알 수 있듯이, 케이블을 꽂거나 분리할 때 힘이 필요하지 않습니다.
케이블을 연결 해제하려면 spudger/스퍼저 끝 또는 손톱으로 작은 잠금 플랩을 위로 올리세요. 그런 다음, 케이블을 안전하게 빼낼 수 있습니다.
커넥터 소켓말고 hinged/힌지 플랩을 들어 올리세요.
이 리본 케이블의 흰색 선은 연결 영역의 가장자리를 표시합니다. 재설치하려면 이 선까지 커넥터에 케이블을 넣은 다음 잠금 플랩을 닫으세요. 케이블이 이 선까지 (또는 매우 가깝게) 들어가지 않는 경우 케이블이 제대로 맞춰지지 않았기 때문이니 케이블을 다시 빼서 위치를 다시 조절하세요.
